We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Turn your mSATA or mSATA Mini drive into a portable, high performance storage solution over USB 3.1 Gen 2. Add high-speed data storage to your laptop or desktop computer, with this portable mSATA and mSATA Mini drive enclosure. It gives you fast data transfer speeds with USB 3.1 (10Gbps) in a solid aluminum enclosure.
With its compact design and metal housing, the mSATA drive enclosure gives you a highly portable, high-speed storage solution. Slim and stylish, the enclosure makes the ideal accessory for laptop or desktop computers.
The mSATA enclosure provides dependable drive protection with its durable, solid aluminum housing. It also features ventilation holes to help protect your drive from overheating by allowing heat to dissipate and help maintain an optimum operating temperature.
With support for USB 3.1 (also known as USB 3.1 Gen 2) and SATA III (6Gbps) host connections, the drive enclosure lets you maximize the performance of your mSATA solid-state drives to achieve greater data transfer speeds. The mSATA drive enclosure also supports UASP for enhanced performance.
This portable drive enclosure is compatible with all standard mSATA drives, including the mSATA Mini (Half-Size) form factor.
Product Description | StarTech.com USB 3.1 Gen 2 (10Gbps) Enclosure - Portable mSATA SSD Enclosure - Aluminum mSATA Drive Enclosure with UASP (SMS1BMU313) - storage enclosure - SATA 6Gb/s / mSATA - USB 3.1 (Gen 2) | Device Type | Storage enclosure - external | Bus Type | USB 3.1 (Gen 2) | Colour | Black, silver | Expansion Bays | 1 x internal - mSATA | Hard Drive Form Factor Compatibility | mSATA, mSATA mini | Interface | SATA 6Gb/s / mSATA | Data Transfer Rate | 6 Gbit/s | Supported Devices | Solid state drive | Max Storage Devices Qty | 1 | Product Material | Aluminium | Power Source | USB bus | Dimensions (WxDxH) | 4.15 cm x 9.85 cm x 1.2 cm | Weight | 55 g | Manufacturer Warranty | 2-year warranty |
General | |
Hard Drive Maximum Height | 50.8 mm |
Host Bus | USB 3.1 (Gen 2) |
Storage Controller | |
Processor | ASMedia ASM1351 |
Expansion / Connectivity | |
Interfaces | 1 x mSATA - mSATA (internal) |
Connections | 1 x USB 3.1 (Gen 2) - 9 pin Micro-USB Type B |
Miscellaneous | |
Included Accessories | Screwdriver, 4 x screws |
Cables Included | 1 x micro-USB to USB cable - external |
Features | LED indicator, UASP transfer protocol, ventilation holes, tested with up to 1TB mSATA drives |
Compliant Standards | FCC, RoHS, WEEE, RCM |
Power | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Dimensions & Weight | |
Width | 4.15 cm |
Depth | 9.85 cm |
Height | 1.2 cm |
Weight | 55 g |
