BT.com
Wishlist
StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD
StarTech.com USB 3.0 to SATA Hard...
£41.85
13 in stock
£41.85
Add to wishlist
Delivery
Standard 3-5 working days
Enable fast, swappable access to your 2.5in or 3.5in SATA hard drives, through USB 3.0.
The SATDOCKU3S USB 3.0 Hard Drive Docking Station delivers full, instant access to any 2.5in or 3.5in SATA (SATA, SATA II, SATA III) hard drive (HDD) or solid state drive (SSD), without having to mount the drive in a computer or install it in an external enclosure. Large capacity drives (tested with up to 4TB) can be used to greatly enhance your computer's storage/backup capabilities.
Connected to the host computer through a single USB 3.0 SuperSpeed or USB 2.0 connection, the hard drive docking station provides a convenient, plug-and-play storage solution that delivers instant access to the hard drive without requiring a reboot.
Relying on the outstanding data throughput support of USB 3.0, the HDD docking station is capable of transfer speed up 5Gbps, making it the fastest way to access data from an external drive. Double the value of this hard drive docking station, using a SATA to IDE hard drive adapter (SAT2IDEADP), which enables you to use any 2.5 or 3.5in IDE hard drive in a SATA hard drive dock slot.
StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD - HDD docking station - SATA 3Gb/s - USB 3.0
HDD docking station - external
Bays
1
Bus Type
USB 3.0
Expansion Bays
1 x hot-swap - 2.5" / 3.5" shared
Hard Drive Form Factor Compatibility
2.5", 3.5"
SATA 3Gb/s
Data Transfer Rate
300 MBps
Supported Devices
Hard drive
Power Source
Included AC adapter
AC 120/230 V
Microsoft Windows Server 2003, Apple MacOS X or later, Microsoft Windows 7, Microsoft Windows Vista / 2000 / XP, Microsoft Windows Server 2008
9.3 cm x 14.5 cm x 6.5 cm
410 g
2 years warranty
Bays
1
2.5", 3.5"
Host Bus
USB 3.0
Storage Controller
SATA 3Gb/s
Data Transfer Rate
300 MBps
Supported Devices
Hard drive
Bays
1 x SATA 3Gb/s - 15 pin Serial ATA power , 1 x SATA 3Gb/s - 7 pin Serial ATA
1 x USB 3.0 - 9 pin USB Type B
1 x USB cable - external , 1 x Serial ATA cable - external
Tested with up to 4TB 5400 RPM 3.5” hard drives, tested with up to 1TB 5400 RPM 2.5” hard drives
Plug and Play, FCC, RoHS
Power Source
Included AC adapter
Power adapter
AC 120/230 V
9.3 cm
14.5 cm
6.5 cm
410 g
5 °C
80 °C
8 - 80%
Other bundles
StarTech.com USB 3.0 to SATA Hard Drive Docking Station...
£41.85
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.45
£45.30
Accessories
£4.83
£7.50
£9.07
£5.88
£5.82
£41.85
£20.91
£12.75
Scroll to top
