BT.com
Wishlist
StarTech.com USB 3.0 to HDMI External Multi Monitor Graphics Adapter with 3-Port USB Hub
Delivery
Standard Due date unavailable
Connect an HDMI-equipped display through USB 3.0, and add three additional USB devices to the same USB 3.0 port with a built-in USB 3.0 hub. The USB32HDEH3 USB 3.0 to HDMI Adapter turns a USB 3.0 port into an HDMI output port with 1920x1200/1080p video support. The adapter features a built-in 3-port USB 3.0 hub, which enables you to connect three different USB devices, along with the display adapter, to the same USB 3.0 port - an ideal workaround for Ultrabook or laptop computers that have a limited number of USB ports available.
Functioning as an external graphics card with audio support, this USB to HDMI adapter provides a convenient way to add multi-monitor capability to a USB 3.0-enabled desktop or laptop computer. Leveraging the high-bandwidth (5 Gbps) USB 3.0 interface, the adapter delivers smooth, high-definition content to your HDMI display / projector. The adapter can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity.
The USB32HDEH3 also features a built-in 3-port USB 3.0 hub, which lets you use the device as a mini dock for connecting peripherals such as a mouse, printer and keyboard along with your monitor. Then, it's as easy as connecting your laptop to the adapter to sync each device at your work station - a versatile solution for making your laptop portable when you want it to be, and powerful when you need it to be.
StarTech.com USB 3.0 to HDMI External Graphics Adapter with 3-Port USB Hub - external video adapter - T5-302 - 16 MB - black
External video adapter
Bus Type
SuperSpeed USB 3.0
Graphics Engine
MCT Trigger 5 T5-302
16 MB DDR2
Max Resolution
1920 x 1200
3 x USB 3.0 , HDMI
4.4 cm x 23.5 cm x 1.4 cm
Enclosure Colour
2 years warranty
Bus Type
SuperSpeed USB 3.0
Graphics Engine
Max Resolution
1920 x 1200
3 x USB 3.0 , HDMI
USB powered, USB Pass-Through
Size
16 MB
DDR2 SDRAM
1 x SuperSpeed USB cable - 14.6 cm
WHQL, FCC, RoHS
4.4 cm
23.5 cm
1.4 cm
63 g
Enclosure Colour
50 °C
0 - 85% (non-condensing)
Accessories
£13.14
Scroll to top
