BT.com
Wishlist
StarTech.com USB 3.0 to 4-Bay SATA 6Gbps Hard Drive Docking Station w/ UASP & Dual Fans
StarTech.com USB 3.0 to 4-Bay SATA...
£184.09
Hurry, only 2 left in stock!
£184.09
Add to wishlist
Delivery
Standard 1-3 working days
Connect and swap four 2.5/3.5" SATA III (6 Gbps) drives through USB 3.0 with UASP. The SDOCK4U33 four-bay 2.5/3.5" SATA HDD / SSD docking station lets you dock and swap four drives from your desktop or laptop computer simultaneously, using a single USB port.
Get the most out of your SATA III (Gbps) solid state drives and hybrid drives with this UASP (USB Attached SCSI Protocol) enhanced hard drive docking station. With performance up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller, UASP ensures high performance by reducing bottleneck.
The hard drive dock features independently-powered SATA connectors for each individual drive, ensuring you can operate drives separately. This gives you the freedom to hot-swap one drive while transferring data to another, saving you time. Plus, the built-in fans keep your drives running cool, ensuring optimal performance and helps to prevent premature drive failure.
Extend the value of this hard drive docking station further with the addition of the SATA to IDE Hard Drive Adapter (SAT2IDEADP), allowing easy insertion of any 2.5 or 3.5in. IDE hard drive into a SATA hard drive dock.
To ensure compatibility with your computer system, the SDOCK4U33 supports all of the leading operating systems, including: Microsoft Windows (8/7/Vista/XP/Server 2008/Server 2003), Apple OSX (10.9/10.8/10.7/10.6), Linux, and Google Chrome OS.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing, UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP-enabled StarTech.com Enclosure, and a SATA III solid state drive.
StarTech.com USB 3.0 to 4-Bay SATA 6Gbps Hard Drive Docking Station w/ UASP & Dual Fans - 2.5/3.5in SSD / HDD Dock - storage enclosure
Storage enclosure
0 (installed) / 4 (max)
Supported Drives
SATA-600
Linux, Apple MacOS X 10.6, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Google Chrome OS, Apple MacOS X 10.7 Lion, Apple MacOS X 10.8, Apple MacOS X 10.9, Microsoft Windows XP / 7 / 8 / 8.1 (32/64 bits)
AC 120/230 V
17.12 cm x 29.05 cm x 8.73 cm
1.028 kg
2 years warranty
Storage enclosure
Enclosure Colour
Chassis
0
Supported Devices / Modules Qty
4
Supported Drives
SATA-600
Expansion Bays
4 (total) / 4 (free) x external - 2.5" / 3.5" shared
1 x USB 3.0 - 9 pin USB Type B , 4 x SATA 6Gb/s - 22 pin Serial ATA
1 x USB cable
FCC, RoHS
External power adapter
AC 120/230 V
17.12 cm
29.05 cm
8.73 cm
1.028 kg
5 °C
35 °C
20 - 80%
Accessories
£4.83
£7.50
£30.58
£12.75
£37.20
£48.26
Scroll to top
