BT.com
Wishlist
StarTech.com USB 3.0 to 3.5" SATA III Hard Drive Enclosure with Fan and Upright Design - UASP
Delivery
Standard Due date unavailable
Turn a 3.5" SATA HDD into an external upright UASP-supported Hard Drive with built-in fan. The S3510BMU33B 3.5in SATA hard drive enclosure lets you add external storage to your computer by connecting a 3.5" HDD through an available USB 3.0 port.
Enhanced with UASP (USB Attached SCSI Protocol), this enclosure lets you get the most out of your SATA III hard drive with performance up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller.
The enclosure features aluminum housing with a built-in fan to keep your drive running at an optimal temperature at all times. Plus, to help save valuable work space, the enclosure features an upright design that minimizes its footprint and makes it easy to position near your computer.
With support for SATA I/II/III, and large capacity drives (tested up to 4TB) this HDD enclosure is compatible with virtually any 3.5in SATA hard drive, and can greatly increase the storage/backup capabilities of your computer.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing, UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP-enabled StarTech.com Enclosure, and a SATA III solid state drive.
StarTech.com USB 3.0 to 3.5" SATA III Hard Drive Enclosure w/Fan and UASP - storage enclosure - SATA 6Gb/s - USB 3.0
Storage enclosure - external
Bus Type
USB 3.0
Expansion Bays
1 x internal - 3.5"
Hard Drive Form Factor Compatibility
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Supported Devices
Hard drive
Max Storage Devices Qty
1
Product Material
Plastic, aluminium
Power Source
Included AC adapter
AC 120/230 V
Linux, Microsoft Windows 2000, Apple MacOS X 10.6, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Google Chrome OS, Apple MacOS X 10.7 Lion, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks
5.45 cm x 18.05 cm x 14.19 cm
540 g
2 years warranty
3.5"
Host Bus
USB 3.0
Product Material
Plastic, aluminium
Storage Controller
SATA 6Gb/s
Data Transfer Rate
600 MBps
Supported Devices
Hard drive
1
ASMedia ASM1153-6G
Bays
1 x internal - 3.5"
1 x SATA 3Gb/s - 22 pin Serial ATA
1 x USB 3.0 - 9 pin USB Type B
1 x USB cable - external
Tested with up to 4TB 7200 RPM hard drives
WHQL, FCC, RoHS
Power Source
Included AC adapter
Power adapter
AC 120/230 V
5.45 cm
18.05 cm
14.19 cm
540 g
10 - 90%
Accessories
£28.60
£35.82
£27.19
£49.33
£58.30
£20.85
£47.47
£19.06
Scroll to top
