BT.com
Wishlist
StarTech.com USB 3.0 Network Adapter & Hub
StarTech.com USB 3.0 Network...
£35.86
More than 50 in stock
£35.86
Add to wishlist
Delivery
Standard 3-5 working days
Add Gigabit Ethernet connectivity and two USB 3.0 ports to your laptop or tablet through a single USB port. Add powerful network access to your tablet, Ultrabook or laptop, even if it doesn't have a built-in RJ45 port. This USB 3.0 to Gigabit network adapter gives you wired network access - and provides two USB 3.0 pass-through ports allowing you to connect additional USB devices.
Ideal for office or home use, the USB 3.0 network adapter supports full Gigabit bandwidth by harnessing the performance of USB 3.0 (5 Gbps). You can quickly access very large files over a Gigabit network, saving valuable time every day.
Get up and running quickly. Simply plug this Ethernet cable adapter into the USB port on your laptop and connect to your network. The network adapter chipset provides native driver support, so you don't have to worry about installing additional software.
Enhance the capabilities of your laptop or tablet by connecting USB devices like printers or external solid-state drive or hard drive enclosures using the two USB 3.0 ports. You can also connect your mouse, keyboard, flash drive or other low-power USB devices, with no extra power required.
Compact and portable, this USB Gigabit network adapter is the ideal desktop network adapter or laptop accessory. You don't have to carry a power adapter with you to use it, because it's powered directly from the host USB port.
StarTech.com USB 3.0 to Gigabit Network Adapter with Built-In 2-Port USB Hub - network adapter
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
Gigabit Ethernet x 1
6 cm x 25 cm x 2 cm
60 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, GigE
Jumbo frame size: 9000
RTL8153
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
Microsoft Windows CE, Microsoft Windows 98 Second Edition, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 (32/64-bits), Google Chrome OS, Microsoft Windows Server 2012, Apple MacOS X 10.6 - 10.10, Microsoft Windows XP / Vista / 7 / 8 / 8.1 (32/64 bits), Windows 10, Linux Kernel 2.6.25 - 3.17.0
2 years warranty
Network adapter
External
SuperSpeed USB 3.0
Ports
Wired
Cabling Type
Full duplex capability, wake on LAN (WOL), auto-uplink (auto MDI/MDI-X), USB powered, surge protection, built-in 2 port USB 2.0 hub, Jumbo Frames support, Energy Efficient Ethernet
Processor / Memory
RTL8153
1 x 1000Base-T - RJ-45 , 2 x USB 3.0 - 9 pin USB Type A
UL, FCC, RoHS
1092 mAh
6 cm
25 cm
2 cm
60 g
70 °C
Accessories
£7.56
Scroll to top
