BT.com
Wishlist
StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet
StarTech.com Universal VESA LCD...
£34.21
More than 50 in stock
£34.21
Add to wishlist
Delivery
Standard 3-5 working days
Mount a 17-19 inch LCD panel into a standard 19 inch rack/cabinet. The RKLCDBK Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet lets you mount almost any retail LCD or Touch screen panel into a server/storage rack/cabinet. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
The LCD mounting bracket is made of solid cold pressed steel (SPCC), is designed to support 100mm and 75mm VESA mounted LCD panels, and meets ANSI/EIA RS-310-D standards rack mounting. A unique adjustable design enables an LCD panel to be mounted into the cabinet at various depths - allowing the rack/cabinet door to be closed.
The LCD mounting bracket also supports wall-mounted LCD installation, by inverting the adjustable bracket or by adding this bracket to a wall mount bracket or rack, such as the 6U (10 inch) Wallmount Bracket for 19" Rack Equipment (WALLMOUNT6) or 8U Open Frame Wall Mount Equipment Rack (RK812WALLO).
StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet - bracket
Bracket
84.2 cm x 10.8 cm x 17.7 cm
Adjustable Depth
0-8.9 cm
1.7 kg
Recommended Use
LCD display
Recommended Display Size
19"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Material
Solid cold pressed steel
P/N: 2POSTRACK42, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1236BKF, RK2236BKF, RK2536BKF, RK4236BK, RK4242BK, RK960CP
84.2 cm
10.8 cm
17.7 cm
Adjustable Depth
0-8.9 cm
1.7 kg
Material
AV Furniture
Bracket
Recommended Use
LCD display
19"
Adjustable depth
Limited warranty - lifetime
Scroll to top
