BT.com
Wishlist
StarTech.com Spare Hard Drive Tray for the DRW110SATBK Mobile Rack
StarTech.com Spare Hard Drive Tray...
£19.95
Hurry, only 1 left in stock!
£19.95
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Monday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Keep spare hard drive trays handy for the DRW110SATBK Mobile Rack. This spare/extra SATA hard drive caddy/drive tray can be used with StarTech.com's 5.25in SATA Hard Drive Mobile Rack Drawer (DRW110SATBK) allowing you to hot swap an additional SATA hard drive, swap operating systems, make high speed, high capacity backups or provide individual hard drives for multiple users.
To maximize performance and utilize the full speed potential of your SATA III hard drives, this HDD Backplane supports SATA III for transfer speeds up to 6 Gbps when paired with compatible controller.
StarTech.com Spare Hard Drive Tray for the DRW110SATBK Mobile Rack - hard drive caddy
Hard drive caddy
Expansion Bays
1 x internal - 3.5"
Compatible Bay
1
Hard Drive Form Factor Compatibility
3.5"
Supported Interface
SATA 1.5Gb/s
Drive Connector
7 pin Serial ATA
Bay Connector
7 pin Serial ATA
Shock protection
Product Material
Plastic
12 cm x 19.6 cm x 4.1 cm
0.3 kg
2 years warranty
Hard drive caddy
3.5"
Product Material
Plastic
Supported Interface
SATA 1.5Gb/s
Shock protection
Bays
1 x internal - 3.5"
1 x SATA 1.5Gb/s - 7 pin Serial ATA
1 storage - Serial ATA-150 - 7 pin Serial ATA
Compatible Bay
1 x external
12 cm
19.6 cm
4.1 cm
0.3 kg
Accessories
£19.95
Scroll to top
