BT.com
Wishlist
StarTech.com Sit Stand Desk Converter - 35"
Delivery
Standard 1-3 working days
This sit-stand workstation transforms your current desk or tabletop into an ergonomic workspace, easily and cost-effectively. The height-adjustable standing desk converter sits on your desk to function just like a standing desk, providing a large work surface that holds two 24" monitors. Move it up or down with one smooth motion, to work in greater comfort and remain productive without disrupting your work while switching from a seated to standing position.
The sit-stand desk converter comes fully assembled, so you can be up and running quickly.
Moving between sitting and standing throughout your work day brings many health benefits, from increased circulation to reduced fatigue. The sit-stand workstation makes it easy to change your position throughout the day.
Change the height of your work surface, effortlessly, with a full 22" (560 mm) of vertical extension. You simply squeeze the lever at the side, and then move the workstation up or down smoothly, using pneumatic technology. Its straight up-and-down movement saves space and provides a stable platform as it moves, with no fear of tipping.
Plus, there are no preset levels, so you can find the precise height you need to work most comfortably. It also offers a counterbalance feature, so you can adjust the tension according to the weight of your monitors, to raise or lower the work surface with ease.
The sit-stand workstation is conveniently sized for easy integration into your workspace. It's large enough (35.4" wide) to hold two 24" monitors, yet small enough to fit on most desks or other surfaces. Whether you work in an office setting, cubicle, or home office, the sit-stand workstation sits easily on your desk or work surface, and even works well for corner desks. It works well on a variety of surfaces that are 24" or deeper. The work surface supports a weight capacity of 28.1 lb. (12.7 kg).
The desktop workstation also features a large keyboard tray, with plenty of room for personal items like your phone.
The sit-stand desktop workstation comes fully assembled so you'll be up and running quickly. It also includes cable management to keep your cables organized and out of sight.
StarTech.com Sit Stand Desk Converter - With 35" Work Surface - mounting kit
Mounting kit - desktop
Mounting Components
Keyboard tray, work surface
Adjustments
Recommended Use
LCD display / keyboard / mouse / notebook
Recommended Display Size
24"
Max Load Weight
12.7 kg
2 years warranty
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Placing / Mounting
Desktop
Cable Management
Integrated cable management
24"
Adjustments
Max Load Weight
12.7 kg
Scroll to top
