BT.com
Wishlist
StarTech.com SATA to LP4 Power Cable Adapter with 2 Additional LP4
StarTech.com SATA to LP4 Power...
£5.44
38 in stock
£5.44
Add to wishlist
Delivery
Standard 3-5 working days
Power up to 3 devices using a SATA power connector from the computer power supply.
The LP4SATAFM2L SATA to LP4 Power Cable lets you power an IDE (LP4-connected) drive using a SATA power connector from the computer power supply. The adapter features two additional LP4 power connectors, offering the versatility to connect two additional (LP4 connected) drives (CD/DVD-ROM, HDD, etc.) using the same single connection to the computer power supply.
This high quality LP4/SATA power adapter cable is expertly designed for durability.
StarTech.com SATA to LP4 Power Cable Adapter with 2 Additional LP4 - power adapter - 15 cm
Power adapter
Length
15 cm
Connector
3 x 4 PIN internal power - female
Connector (Second End)
15 pin Serial ATA power - male
P/N: SATSASBAY425, ATX2POWER430, ATX2POWER530
Power adapter
Length
15 cm
Connector
RoHS
StarTech.com 4 Drive 2.5in Removable SAS SATA Mobile Rack Backplane, 430 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC, 530 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC
Scroll to top
