BT.com
Wishlist
StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks
StarTech.com SATA to 2.5in or 3.5in...
£20.91
38 in stock
£20.91
Add to wishlist
Delivery
Standard 3-5 working days
The SAT2IDEADP SATA to IDE hard drive adapter allows for 2.5in/3.5in IDE-based (PATA) hard drives (HDD) to be used in most StarTech.com SATA-based HDD docking stations and drive duplicators. The unique mounting style of the SATA/IDE adapter enables it to be easily mounted to IDE/ATA hard drive and inserted into SATA hard drive dock bay, for quick and easy retrieval of data from older HDDs while its all- metal construction ensures maximum durability. The SAT2IDEADP hard drive adapter works with most StarTech.com SATA HDD Docking Stations and Duplicators, including: SATADOCK22UE, SATDOCK2UEGB, SATDOCK22RE, SATDOCK22R, SATDOCKU3S, SATADOCKU2, SATADOCKU2E, SATDOCK4U2E, SATDOCK4U3E, SATDOCKCRH, SATDOCKU2EGB, SATDOCKU2GB. Fully compatible with both 2.5in and 3.5in form factor hard drives and up to ATA-133 (133 MBps), this versatile HDD adapter can also be used to install IDE hard drives into SATA-only desktop computers, or many other scenarios that require an IDE HDD be connected through SATA.
StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks - storage controller - ATA-133 - SATA
Storage controller - internal
Bus Type
SATA
Hard Drive Form Factor Compatibility
2.5", 3.5"
ATA-133
Data Transfer Rate
133 MBps
Supported Devices
Hard drive
Channel Qty
1
7.8 cm x 10.1 cm x 2.6 cm
104 g
2 years warranty
P/N: SATADOCKU2GB, SATDOCKU2EU, SATDOCKU2EEU, SATDUPUEGB, SATDUPUEEU, SATDOCK2UEEU, SATDOCK4U3E, SATDOCK4U2E, SATDOCK22RE, SATDOCKU3S, SATDOCKCRHGB, SATDOCKCRH, SATDOCK22R, SATDOCKU2GB, SATDOCKU2EGB, SATDOCK2UEGB, SATADOCKU2E, SATADOCKU2, SATADOCK22UE
2.5", 3.5"
Host Bus
SATA
Storage Controller
ATA-133
Data Transfer Rate
133 MBps
Supported Devices
Hard drive
Channel Qty
1
1 x ATA-133 - 40 PIN IDC
1 storage - Serial ATA-150 - 7 pin Serial ATA
FCC, RoHS
Limited warranty - 2 years , Technical support - lifetime
7.8 cm
10.1 cm
2.6 cm
104 g
5 °C
80 °C
8 - 90%
StarTech.com 4 Bay eSATA USB 2.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD, 4 Bay eSATA USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD, eSATA USB to SATA External HDD Dock for 2.5 or 3.5in, eSATA USB to SATA External HDD Dock for Dual 2.5 or 3.5in Hard Drive, eSATA USB to SATA HDD Docking Station w/ Hub/Card Reader, eSATA USB to SATA Standalone Hard Drive Duplicator Dock, USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD, USB to SATA External HDD Dock for 2.5 or 3.5in Hard Drive, USB to SATA Standalone Hard Drive Duplicator Dock
Accessories
£191.24
£38.55
£20.91
Scroll to top
