Click to visit BT.com
BT.com
Wishlist
StarTech.com SATA Hard Drive HDD Duplicator Dock - eSATA USB
Quicklinx: 76PZWS00
Mfr#: SATDOCK22RE
Type: Storage enclosure
HD Size: 2.5" / 3.5" shared
Power Supply: Power supply
Express delivery Delivered on Tuesday
Hurry, only 1 left in stock!
£53.74
Exactly duplicate one 2.5in or 3.5in SATA hard drive to another, effortlessly and without a computer.
The SATDOCK22RE USB and eSATA Standalone Duplicator Dock lets you duplicate/clone an existing hard drive without the use of a host computer system, or can be connected to a computer system for use as an external hard drive dock.
As a hard drive duplicator, you can create an exact 1 to 1 sector clone from one hard drive to another, including partition and boot sector information and all data, at a rate of 72MB/second - ensuring data integrity and consistency for sensitive operations, such as data recovery.
As an external hard drive dock, the duplicator/dock supports plug-and-play installation and can be connected to your host computer through USB 2.0 or eSATA, providing data transfer speeds up to 480Mbps or 3Gbps respectively from the hard drives to your computer system. Large capacity drives (tested with up to 4TB 3.5" and 1TB 2.5" drives per bay) can be used to greatly enhance your computer's storage/backup capabilities.
Not having to install the hard drives into an enclosure or tray system allows for quick setups - a perfect solution for situations that require swapping through multiple drives, which combined with no driver or software installation requirements delivers a convenient and versatile storage solution. The value of this hard drive docking station can be extended, using a SATA to IDE hard drive adapter (SAT2IDEADP), which enables you to use any 2.5 or 3.5in IDE hard drive in a SATA hard drive dock slot.
StarTech.com SATA Hard Drive HDD Duplicator Dock - eSATA USB - hard drive duplicator
Hard drive duplicator
0 (installed) / 2 (max)
Supported Drives
SATA-300
Storage Controller
SATA ( SATA 3Gb/s )
Hard Drive
No HDD
Linux, Microsoft Windows 2000, Apple MacOS X 10.4, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7 Lion, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits)
AC 120/230 V - 50/60 Hz
13.2 cm x 14.7 cm x 7 cm
0.55 kg
2 years warranty
P/N: SAT2IDEADP
Enclosure Colour
Chassis
0
Supported Devices / Modules Qty
2
Supported Drives
SATA-300
JMB352U
Storage Controller
SATA - integrated ( USB 2.0 / eSATA 3Gb/s )
Interface Type
SATA 3Gb/s
Data Transfer Rate
300 MBps
Supported Devices
Hard drive
Max Storage Devices Qty
2
Hard Drive
No HDD
Expansion Bays
2 (total) / 2 (free) - 2.5" / 3.5" shared - external
1 x USB 2.0 - 4 PIN USB Type B , 1 x eSATA 3Gb/s - 7 pin external Serial ATA , 2 x SATA 3Gb/s - 22 pin Serial ATA
Tested with up to 4TB 5400 RPM 3.5” hard drives, tested with up to 1TB 5400 RPM 2.5” hard drives
Plug and Play, FCC, RoHS
External power adapter
13.2 cm
14.7 cm
7 cm
0.55 kg
2 years warranty
Service & Support Details
5 °C
80 °C
8 - 90%
P/N: SAT2IDEADP
StarTech.com SATA Hard Drive HDD Duplicator Dock - eSATA USB Bundle deal on StarTech.com SATA Hard Drive HDD Duplicator Dock - eSATA USB
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£63.73
76PZ StarTech.com 10 ft Transparent USB 2.0 Cable - A to B In Stock £4.36
76PZ StarTech.com 10 ft USB 2.0 Certified A to B Cable - M/M In Stock £4.10
76PZ StarTech.com 3 ft Shielded External eSATA Cable M/M In Stock £6.67
76PZ StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £4.47
76PZ StarTech.com 1ft Low Profile SATA to eSATA Plate Adapter In Stock £5.42
76PZ StarTech.com 3.5in Silicone Hard Drive Protector Sleeve with Connector Cap In Stock £7.03
76PZ StarTech.com SATA Hard Drive HDD Duplicator Dock - eSATA USB In Stock £53.74
76PZ StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks In Stock £19.00
76PZ StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) In Stock £11.61
76PZ StarTech.com 1 Port SATA to eSATA Slot Plate Bracket In Stock £5.40
Price Range Inc VAT: 50 - 100
