BT.com
Wishlist
StarTech.com PCI Express to 2 PCI & 2 PCIe Expansion Enclosure System - Full Length
StarTech.com PCI Express to 2 PCI &...
£253.00
£253.00
Add to wishlist
Delivery
Standard Due date unavailable
Add two PCI and two PCI Express expansion card slots to your desktop computer. The PEX2PCIE4L PCI/PCI Express Expansion Chassis provides a quick and simple I/O expansion solution to almost any PCI Express (PCIe) enabled system. Adding PCI/PCIe cards to a server or workstation, or providing a platform to swap cards between a mobile and desktop setup is a cost-effective and time-saving solution for maximizing the I/O capabilities of your system.
The external expansion chassis adds two full-length (38cm) PCI slots (32-bit/33MHz), as well as two PCIe x1 (single-lane) slots to a host computer through a single PCI Express connection. Providing total bandwidth up to 250MBps from the PCIe x1 host controller card allows the computer to function as though the expansion chassis cards were connected directly to the motherboard.
StarTech.com PCI Express to 2 PCI & 2 PCIe Expansion Enclosure System - Full Length - system bus extender
System bus extender
38.2 cm x 13.7 cm x 14.3 cm
4 kg
Power adapter - internal AC 120/230 V
2 years warranty
P/N: PCI1PEX1
System bus extender
38.2 cm
13.7 cm
14.3 cm
4 kg
Enclosure Colour
Expansion Slots
2 (total) / 2 (free) x PCI
Compatible Slots
2 x PCI Express x1
1 x DVI cable - external - 91 cm
FCC, RoHS
AC 120/230 V
55 °C
StarTech.com PCI to PCI Express Adapter Card
Accessories
£18.21
£13.27
£18.54
£9.33
Scroll to top
