BT.com
Wishlist
StarTech.com Multi Stream Transport Hub – DisplayPort 1.2 to Triple Head DisplayPort MST Hub
StarTech.com Multi Stream Transport...
£89.88
More than 50 in stock
£89.88
Add to wishlist
Delivery
Standard 3-5 working days
Use this multi-stream transport hub to connect three DP monitors to a single DP 1.2 port. This MST hub lets you connect three monitors to your DisplayPort (DP) 1.2 equipped Windows laptop or desktop.
The newest generations of computers are more portable than ever, which often means that you're left with fewer video outputs and smaller integrated screens. This MST hub solves both of these problems by letting you connect three additional displays to your computer, which makes multitasking much easier.
With the MST hub, you can use DisplayPort video adapters and cable adapters that enable you to connect HDMI, VGA or DVI displays. This ensures your MST hub will be compatible with virtually any television, monitor or projector. This MST hub is VESA and DisplayPort certified to support DP 1.2 enabled systems, for seamless integration with your existing video equipment.
Using the MST hub, you can extend your desktop onto additional monitors and stream independent content to each display giving you the freedom to multitask and increase your productivity. You can also mirror the same image onto multiple displays for remote viewing applications such as digital signage.
MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. This unprecedented performance makes MST perfect for high-resolution applications such as graphic design, gaming and medical imaging.
Note: When using a DisplayPort 1.1 video card the MSTDP123DP will act as splitter, automatically mirroring your video source across all displays. Resolution limitations apply.
The MSTDP123DP supports plug-and-play installation for a hassle-free setup.
StarTech.com DisplayPort to DP Multi Monitor Splitter - 3-Port MST Hub - video splitter - 3 ports
Video splitter - 3 ports
AC 100/230 V
7.8 cm x 2 cm x 20 cm
95 g
2 years warranty
Bundled Services
2 years warranty
Enclosure Type
Desktop
Max Resolution
2560 x 1600
3 x DisplayPort , 1 x DisplayPort
External power adapter
AC 100/230 V
FCC, RoHS
7.8 cm
2 cm
20 cm
95 g
45 °C
Accessories
£19.10
£10.99
£15.54
£20.66
Scroll to top
