BT.com
Wishlist
StarTech.com Mini PCI Express Wireless N Card - 300Mbps Mini PCIe 802.11b/g/n WiFi Adapter - 2T2R
Delivery
Standard Due date unavailable
Add high speed Wireless-N connectivity through a Mini PCI Express slot. The MPEX300WN2X2 Mini PCI Express Wireless N Card lets you add high-speed 802.11n network connectivity to your laptop or small form factor system, with support for data transfer rates up to 300Mbps.
For efficient wireless communication, the card uses a 2T2R (2 Transmitter, 2 Receiver) Multiple Input/Multiple Output design over the 2.4GHz frequency. MIMO antenna configurations employ multiple signal paths for greater bandwidth, fewer lost packets and greater reception, even under conditions of interference.
The 300Mbps wireless N adapter offers the necessary speeds for demanding network applications such as streaming video, VoIP and network backups, while also offering backward compatibility with 802.11b/g networks (11/54Mbps) to connect to older WiFi routers as needed.
Using a half-height mini PCI express (Half Mini Card) form factor, this adapter is designed for use in the latest notebooks, small form factor computers (e.g. Mini-ITX), or custom embedded solutions where standard PCIe cards would not fit.
StarTech.com Mini PCI Express Wireless N Card - 300Mbps 802.11b/g/n 2T2R - network adapter
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express Mini Card
2.65 cm x 0.3 cm x 2.98 cm
4 g
802.11b, 802.11g, 802.11n
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Microsoft Windows Server 2008 R2, Microsoft Windows Vista / XP / 7, Linux Kernel 2.6.35, Windows 8, Microsoft Windows Server 2012, Windows 10 (32/64 bits)
2 years warranty
Network adapter
Plug-in card
Wireless
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
2T2R MIMO technology
FCC, RoHS
2.65 cm
0.3 cm
2.98 cm
4 g
10 - 90%
Scroll to top
