BT.com
Wishlist
StarTech.com Mini DVI to HDMI Video Adapter for Macbooks and iMacs- M/F
StarTech.com Mini DVI to HDMI Video...
£13.40
More than 50 in stock
£13.40
Add to wishlist
Delivery
Standard 3-5 working days
This Mini DVI to HDMI Adapter cable features one 32 pin mini-DVI Male and one HDMI Female connector, allowing the video signal from a mini DVI equipped device to be output to an HDMI equipped TV set or A/V Receiver.
This is the perfect solution for using your HDTV instead of a computer monitor, or watch movies directly on your TV from your Apple MacBook or iMac Computer.
MDVIHDMIMF will not work with the current MacBooks, it is made for MacBooks that use mini DVI connectors
StarTech.com Mini DVI to HDMI Video Adapter for Macbooks and iMacs- M/F - video adapter - HDMI / DVI - 20 cm
Cable
Video adapter - HDMI / DVI
Length
20 cm
White
Connector
Mini-DVI - male
Connector (Second End)
HDMI - female
Apple iMac; MacBook
Cable Type
Video adapter
Interface Supported
HDMI / DVI
Length
20 cm
White
Connector
Apple mini-DVI - male
19 pin HDMI Type A - female
Limited warranty - lifetime
Apple iMac , Apple MacBook
Scroll to top
