BT.com
Wishlist
StarTech.com Industrial 1 Port Gigabit PoE+ Power over Ethernet Injector (30W) w/ Non-Standard PoE
Delivery
Standard Due date unavailable
The POEINJ1GI Industrial Gigabit PoE+ Injector provides power and data connectivity to a Gigabit PoE-compliant device over standard Ethernet cabling at distances of up to 330ft (100m), and offers redundant, wide-range DC power inputs. This injector allows you to easily connect a PoE-powered device (PD) to a non-PoE LAN switch, avoiding the cost of upgrading your switch to a PoE-enabled model.
Providing seamless power failover in the event of power dips or failures, the injector features redundant 20-57V DC (nominal 24/48V DC) terminal block power inputs. The internal DC-DC converter provides the PoE injector with high voltage output from a low voltage input (<24V DC). When used with multiple power sources, the injector also supports alarm relay contacts, which can be wired to your existing alarm circuit to give you instant notice when a power disruption occurs.
Fully compliant with IEEE 802.3at / 802.3af, the injector provides a 10/100/1000Mbps port with support for up to 30 Watt max output, and up to 60 Watts output for non-standard PoE devices.
To ensure dependable performance in harsh environments this power over Ethernet injector features a rugged, IP-30 case design with flexible DIN rail or wall-mountable installation options.
Backed by a 2-year StarTech.com warranty and free lifetime technical support.
The StarTech.com Advantage
  • Maintain device operation during power disruptions with redundant power inputs
  • Versatile installation options with included DIN rail and wall-mount brackets
  • Operate under harsh industrial conditions with an IP-30 rated, rugged housing
Applications
  • Ideal for high-power PoE+ devices requiring Gigabit speeds such as a security camera or network webcam in remote areas where a power connection is not available
  • Power non-standard, high-draw PoE devices such as seasonal cameras with fans or heaters
  • Industrial locations where critical equipment requires backup power
  • Perfect for powering a Wireless Access Point(WAP) in a business environment
  • Retail applications such as RFID readers
  • Enable remote installation of touchscreens or information kiosks
StarTech.com Industrial 1 Port Gigabit PoE+ Power over Ethernet Injector 48V / 30W with Redundant Power - DIN Rail/Wall-Mountable - PoE injector - 30 Watt
PoE injector - external
0.7 kg
Input Voltage
24 / 48 V
Output Voltage
48 V
Power Capacity
30 Watt
Output connectors
1 x RJ-45
14.2 cm x 10.6 cm x 3.9 cm
2 years warranty
Input Voltage
24 / 48 V
1 x RJ-45
Output Voltage
48 V
Power Capacity
30 Watt
1 x Gigabit LAN - RJ-45
Wall mountable
EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, EN 61000-4-5, FCC, EN 61000-6-2, RoHS, EN 61000-4-8, IEC 60068-2-27, IEC 60068-2-32, IEC 60068-2-6, IP30
60 °C
5 - 95% (non-condensing)
14.2 cm
10.6 cm
3.9 cm
0.7 kg
Shipping Weight
1 kg
Accessories
£8.66
£287.76
£121.74
Scroll to top
