BT.com
Wishlist
StarTech.com IDE to SATA Adapter Converter
StarTech.com IDE to SATA Adapter...
£13.42
45 in stock
£13.42
Add to wishlist
Delivery
Standard 3-5 working days
Connect 2 SATA hard drives to an IDE motherboard or card. This IDE to SATA Drive Adapter Kit offers a simple way to install Serial ATA hard drives using an available IDE port - a cost-effective solution for using newer SATA drives on a legacy computer or a computer with all SATA connections already in use.
This dual channel bridge lets you connect two high-speed SATA drives without the cost and effort of upgrading your IDE (Parallel ATA) motherboard, while minimizing the space required for IDE cable connections - helping to improve airflow within the case which in turn helps to optimize system performance.
Plus, the IDE to SATA Drive Motherboard Adapter includes a power connector and SATA data cables, to ensure the upgrade to SATA is easy!
To connect to a power source, SATA hard drives require SATA power. If your computer's power supply does not have a SATA power connection, the SATAPOWADAP 6in LP4 Male to Serial ATA Power Adapter will be required.
StarTech.com IDE to SATA Adapter Converter - storage controller - SATA 1.5Gb/s - Ultra ATA/133
Storage controller
Bus Type
Ultra ATA/133
SATA 1.5Gb/s
Data Transfer Rate
150 MBps
Supported Devices
Hard drive, CD drive, DVD drive
Channel Qty
2
Max Storage Devices Qty
2
4.6 cm x 5.4 cm x 1.1 cm
13 g
Storage controller
Host Bus
Ultra ATA/133
Storage Controller
SATA 1.5Gb/s
Data Transfer Rate
150 MBps
Supported Devices
Channel Qty
2
2
2 x SATA 1.5Gb/s - 7 pin Serial ATA
1 storage - ATA-133 - 40 PIN IDC
2 x Serial ATA cable
FCC, RoHS
Service & Support Details
Limited warranty - lifetime
4.6 cm
5.4 cm
1.1 cm
13 g
Other bundles
£13.42
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.45
£16.87
Accessories
£3.55
StarTech.com 24" Serial ATA Cable
Quicklinx: 3ZLH | In Stock
£4.27
StarTech.com 18" Serial ATA Cable w/R Angle
Quicklinx: 3ZLJ | In Stock
£4.23
£5.97
StarTech.com 18in SATA Serial ATA Cable
Quicklinx: 3ZLL | In Stock
£4.05
StarTech.com 36in SATA Serial ATA Cable
Quicklinx: 4KXJ | In Stock
£3.79
£4.06
£4.77
Scroll to top
