BT.com
Wishlist
StarTech.com Hot Swap SATA/SAS Backplane RAID Bays – 3 Hard Drive Mobile Rack
StarTech.com Hot Swap SATA/SAS...
£65.72
£65.72
Add to wishlist
Delivery
Standard Due date unavailable
Hot Swap up to three 3.5in SAS or SATA hard drives in and out of this removable backplane; features 3-in-2 design, that requires only two 5.25in drive bays. The SATSASBAY3BK SAS/SATA Backplane offers an easy-to-use and cost-effective SATA hot swap solution and features a sturdy and compact 3-in-2 design that lets you install up to three 2.5"/3.5" SATA or SAS hard drives into only two 5.25in bays.
With support for SATA/SAS HDD the mobile rack/backplane is fully compatible with RAID installations to ensure maximum performance and versatility for enhanced storage applications.
To maximize performance and utilize the full speed potential of your SATA III hard drives, this HDD Backplane supports SATA III for transfer speeds up to 6 Gbps when paired with compatible controller.
StarTech.com Hot Swap SATA/SAS Backplane RAID Bays 3 Hard Drive Mobile Rack - storage mobile rack
Storage mobile rack
Expansion Bays
3 x hot-swap - 3.5"
Compatible Bay
2 5.25" x 1/2H
Hard Drive Form Factor Compatibility
3.5"
Supported Interface
SATA-300 / SAS
Drive Connector
22 pin Serial ATA
Data indicator, power indicator, cooling fan
Product Material
Plastic, aluminium, steel
14.6 cm x 20.2 cm x 8.6 cm
1.2 kg
1 year warranty
Storage mobile rack
3.5"
Product Material
Supported Interface
SATA-300 / SAS
Bays
3 x hot-swap - 3.5"
3 x SATA 3Gb/s / SAS - 22 pin Serial ATA
1 storage - Serial ATA-300 - 7 pin Serial ATA , 2 storage - Serial ATA-300 - 22 pin Serial ATA
Compatible Bay
2 x external 5.25" x 1/2H
FCC, RoHS
Limited warranty - 1 year
14.6 cm
20.2 cm
8.6 cm
1.2 kg
50 °C
Accessories
StarTech.com 24" Serial ATA Cable
Quicklinx: 3ZLH | In Stock
£4.27
£5.97
StarTech.com 36in SATA Serial ATA Cable
Quicklinx: 4KXJ | In Stock
£3.79
StarTech.com 24in Latching SATA Cable
Quicklinx: 4LTL | In Stock
£5.01
£5.22
£3.96
Scroll to top
