Click to visit BT.com
BT.com
Wishlist
StarTech.com Hot Swap SATA/SAS Backplane RAID Bays – 3 Hard Drive Mobile Rack
Quicklinx: 6PDDWS00
Mfr#: SATSASBAY3BK
Type: Storage Enclosure
Standard delivery Delivered within 3-5 working days
21 in stock
£73.15
Hot Swap up to three 3.5in SAS or SATA hard drives in and out of this removable backplane; features 3-in-2 design, that requires only two 5.25in drive bays. The SATSASBAY3BK SAS/SATA Backplane offers an easy-to-use and cost-effective SATA hot swap solution and features a sturdy and compact 3-in-2 design that lets you install up to three 2.5"/3.5" SATA or SAS hard drives into only two 5.25in bays.
With support for SATA/SAS HDD the mobile rack/backplane is fully compatible with RAID installations to ensure maximum performance and versatility for enhanced storage applications.
To maximize performance and utilize the full speed potential of your SATA III hard drives, this HDD Backplane supports SATA III for transfer speeds up to 6 Gbps when paired with compatible controller.
StarTech.com Hot Swap SATA/SAS Backplane RAID Bays 3 Hard Drive Mobile Rack - storage mobile rack
Storage mobile rack
Expansion Bays
3 x hot-swap - 3.5"
Compatible Bays
2 5.25" x 1/2H
Hard Drive Form Factor Compatibility
3.5"
Supported Interface
SATA-300 / SAS
Drive Connector
22 pin Serial ATA
Data indicator, power indicator, cooling fan
Product Material
Plastic, aluminium, steel
14.6 cm x 20.2 cm x 8.6 cm
1.2 kg
1 year warranty
Storage mobile rack
3.5"
Product Material
Supported Interface
SATA-300 / SAS
Bays
3 x hot-swap - 3.5"
3 x SATA 3Gb/s / SAS - 22 pin Serial ATA
1 storage - Serial ATA-300 - 7 pin Serial ATA , 2 storage - Serial ATA-300 - 22 pin Serial ATA
Compatible Bays
2 x external 5.25" x 1/2H
FCC, RoHS
1 year warranty
Service & Support Details
Limited warranty - 1 year
14.6 cm
20.2 cm
8.6 cm
1.2 kg
50 °C
StarTech.com Hot Swap SATA/SAS Backplane RAID Bays – 3 Hard Drive Mobile Rack Bundle deal on StarTech.com Hot Swap SATA/SAS Backplane RAID Bays – 3 Hard Drive Mobile Rack
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £5.48 | in stock
£77.24
saving £1.39
6PDD StarTech.com 24" Serial ATA Cable In Stock £4.10
6PDD StarTech.com 18in SATA Serial ATA Data and Power Combo Cable In Stock £5.42
6PDD StarTech.com 4 Port PCI SATA RAID Controller Adapter Card In Stock £31.96
6PDD StarTech.com 36in SATA Serial ATA Cable In Stock £3.66
6PDD StarTech.com 24in Latching SATA Cable In Stock £4.46
6PDD StarTech.com SATA to LP4 Power Cable Adapter In Stock £5.07
6PDD StarTech.com Hot Swap SATA/SAS Backplane RAID Bays – 3 Hard Drive Mobile Rack In Stock £73.15
6PDD StarTech.com 6in LP4 to LP4 SATA Power Y Cable Adapter In Stock £3.68
6PDD StarTech.com 24in Right Angle SATA Cable In Stock £2.43
6PDD StarTech.com 24in SATA Serial ATA Data and Power Combo Cable In Stock £6.33
Price Range Inc VAT: 50 - 100
