BT.com
Wishlist
StarTech.com HDMI over IP Extender w/ Audio
Delivery
Standard Due date unavailable
Connect to, and share an HDMI display or projector over an IP network.
The IPUSB2HD2 HDMI over IP Extender delivers a versatile HDMI-IP link between PCs on your network and an HDMI monitor/projector, at full high definition (1080p, 1920x1080) video resolution. Accompanying audio signals are transmitted directly through the HDMI output, or separately through the built-on 3.5mm stereo output port. An ideal solution for sharing a display or projector over an Ethernet network so that even PCs lacking digital video output can still connect, the IP/HDMI adapter can communicate through a network router at transmission distances up to 100m (300ft). Plus, it offers 2 USB 2.0 ports on the display side, to connect and share peripherals such as USB storage or keyboard/mouse input with the connected PC. Alternatively, the device can be used directly connected as a USB to HDMI adapter.
StarTech.com HDMI over IP Extender with Audio - video/audio extender - GigE, HDMI
Video/audio extender
External
Data Transfer Rate
1 Gbps
GigE, HDMI
Max Transfer Distance
100 m
AC 120/230 V
Microsoft Windows Vista / XP / 7
7.1 cm x 13.3 cm x 2.7 cm
142 g
2 years warranty
External
Wired
GigE, HDMI
Data Transfer Rate
1 Gbps
Max Resolution
1920 x 1080 / 1080p
100 m
1 x - input - RJ-45 female , 1 x display / video - HDMI output - 19 pin HDMI Type A female , 2 x USB 2.0 - Type A female , 1 x mini-USB - Type B female , 1 x microphone (input) - mini jack , 1 x audio (output) - mini jack
WHQL, FCC, RoHS
External power adapter
AC 120/230 V
7.1 cm
13.3 cm
2.7 cm
142 g
70 °C
10 - 80%
Scroll to top
