BT.com
Wishlist
StarTech.com DVI to VGA Video Converter
Delivery
Standard 1-3 working days
Convert and scale a DVI-D signal to work with a VGA monitor. The DVI2VGA DVI to VGA converter with scaler allows you to convert a DVI Digital (DVI-D) signal to a VGA signal, saving you time and money by eliminating the need to purchase costly new hardware to make your devices compatible.
The scaler/converter features an easy to use On-Screen Display (OSD) that allows you to take full control of your display and the resolutions you need, in PC or HDTV mode. The OSD also features adjustments for brightness, color, contrast and horizontal/vertical positioning.
The DVI VGA scaler/converter includes a plastic bracket for wall mounting, or side panel installation.
StarTech.com DVI to VGA Video Converter with Scaler - video converter - black
Video converter
Max Resolution
1280 x 1024
1 x DVI-D input - 24+1 pin digital DVI , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x DVI-D input - 24+1 pin digital DVI (on supplied cable)
7.7 cm x 14.6 cm x 3 cm
Enclosure Colour
2 years warranty
Video converter
Max Resolution
1280 x 1024
1 x DVI-D input - 24+1 pin digital DVI - female , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female , 1 x DVI-D input - 24+1 pin digital DVI (on supplied cable) - male
1 x DVI cable - 1.83 m
7.7 cm
14.6 cm
3 cm
Enclosure Colour
Accessories
£6.90
£7.71
Scroll to top
