BT.com
Wishlist
StarTech.com DVI to VGA Cable Adapter - M/F
StarTech.com DVI to VGA Cable...
£6.22
13 in stock
£6.22
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Monday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
The DVIVGAMF DVI-I to VGA Display Adapter (M/F) is used to convert a DVI Male connector to a VGA female connector. The DVI to VGA adapter is constructed of high quality materials to ensure dependability.
This product is intended for connections between DVI-I and VGA devices. If your device uses a DVI-D connector, please refer to StarTech.com's DVI to VGA Converter DVI2VGACON.
StarTech.com DVI to VGA Cable Adapter - M/F - VGA adapter
VGA adapter
Connector
DVI-I - male
Connector (Second End)
HD-15 - female
Beige
P/N: IP2DVI, SV421DVI, SV221DVI
VGA adapter
Beige
Connector
29 pin combined DVI - male
15 pin HD D-Sub (HD-15) - female
StarTech.com 2 Port DVI PS/2 KVM Switch, Ethernet to DVI Video Adapter over IP , StarTech.com StarView DVI KVM Switch SV421DVI
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Good Stuff
Reviewed by M@ Morgan on 20/01/2007
does what it say it should!! why not buy 2!?
5* Does what it says!
Reviewed by Matt on 14/02/2007
Very good adapter! High quality and does exactly what it says!
Scroll to top
