BT.com
Wishlist
StarTech.com DVI to Mini DisplayPort Adapter with Audio
Delivery
Standard Due date unavailable
The DVI2MDPA DVI to Mini DisplayPort Adapter (with 2-Channel Audio) converts a DVI-D (Digital), Mini-DVI or HDMI source signal and accompanying audio, for use with a Mini DisplayPort or DisplayPort monitor.
The adapter offers easy plug-and-play installation with both PC and Mac platforms, ensuring hardware works seamlessly with your Mini-DisplayPort display to save the time and hassle of hardware upgrades.
A complete, out-of-the-package solution, this DVI-Mini DisplayPort adapter includes all cables necessary for connecting a DVI-D video source and accompanying audio (3.5mm stereo audio) to any Mini DisplayPort monitor, including Apple Cinema HD displays, and can also be used with Mini DVI or Mini HDMI sources using additional cables (sold separately).
Supporting resolutions up to 1920x1200, this USB-Powered device delivers the high resolutions required by many displays.
StarTech.com DVI to Mini DisplayPort Adapter with Audio - video converter - silver
Video converter
Max Resolution
1920 x 1200
1 x DVI-D input - 24+1 pin digital DVI , 1 x DisplayPort output - Mini DisplayPort , 1 x USB - mini-USB Type B , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x DisplayPort output - Mini DisplayPort (on supplied cable) , 1 x audio line-in - mini-phone stereo 3.5 mm (on supplied cable) , 1 x USB - 4 pin USB Type A (on supplied cable)
6.4 cm x 0.7 cm x 7.6 cm
Enclosure Colour
Silver
1 year warranty
Video converter
Max Resolution
1920 x 1200
1 x DVI-D input - 24+1 pin digital DVI - male , 1 x DisplayPort output - Mini DisplayPort - female , 1 x USB - mini-USB Type B - female , 1 x audio line-in - mini-phone stereo 3.5 mm - female , 1 x DisplayPort output - Mini DisplayPort (on supplied cable) - male , 1 x audio line-in - mini-phone stereo 3.5 mm (on supplied cable) - male , 1 x USB - 4 pin USB Type A (on supplied cable) - male
USB powered
Video Output
Supported Display Graphics
1920x1200
DC 5 V
1 x DVI cable - 61 cm , 1 x audio cable , 1 x mini-USB to USB cable , 1 x Mini DisplayPort cable
Plug and Play, RoHS
6.4 cm
0.7 cm
7.6 cm
200 g
Enclosure Colour
Silver
Limited warranty - 1 year
70 °C
10 - 85%
Accessories
StarTech.com 6 ft HDMI to DVI-D Cable - M/M
Quicklinx: 4JDR | In Stock
£7.92
£8.22
£9.09
£11.24
£17.88
£3.39
Scroll to top
