BT.com
Wishlist
StarTech.com Dual fan hard drive cooling kit
Delivery
Standard Due date unavailable
The StarTech.com dual fan hard drive cooling kit provides maximum airflow for hot-running hard drives, preventing overheating failures and extending the life of the drive. The fan unit mounts in any free 5.25-inch half-height drive bay, and the hard drive is mounted directly behind it using the supplied 3.5-inch to 5.25-inch adapter brackets. Fresh cool external air is drawn into the case through a removable, cleanable filter and blown directly over the hard drive by 2 quiet running fans. Perfect for extending the life of hot running hard drives in servers or workstations.
StarTech.com 5.25in Front Bay Mount Dual Fan Hard Drive Cooler - hard drive cooler
Hard drive cooler
Noise Level
36 dB
Product Material
Plastic
15 cm 4 cm
Hard drive cooler
Product Material
Plastic
15 cm
4 cm
Heatsink & Fan
Noise Level
36 dB
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
1* Useless
Reviewed by Mike on 04/07/2011
Despite the claim that this drive fan fits any 5.25 inch drive bay it doesn't fit any of the machines here. The fan assembly appears to occupy the front set of screw holes in the case which leaves only the rear set to mount the drive (using the included brackets.) This wouldn't adequately support the drive normally but in my case the case only provided the lower set of screw holes so the drive would have been free to pivot. :(
Scroll to top
