Click to visit BT.com
BT.com
Wishlist
StarTech.com DisplayPort to HDMI Video Adapter Converter
Quicklinx: 67B2WS00
Mfr#: DP2HDMI
Express delivery Order within the next 18 hours for delivery on Thursday
16 in stock
£17.66
Connect your HDMI monitor or HDTV to a DisplayPort equipped computer. The StarTech.com DisplayPort to HDMI adapter lets you connect an HDMI-enabled video display to a DisplayPort video source (e.g.DisplayPort video cards, etc.), eliminating the expense of having to upgrade your display for DisplayPort compatibility.
This adapter supports display resolutions of up to 1920x1200 allowing you to take full advantage of HDMI video capability.
DP2HDMI is a passive adapter cable that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
This adapter allows for audio pass-through if supported by the video source. Please review the video source manual to confirm support.
StarTech.com DisplayPort to HDMI Video Converter - video adapter - DisplayPort / HDMI - 24 cm
Cable
Video adapter - DisplayPort / HDMI
Length
24 cm
Connector
HDMI Type A - female
Connector (Second End)
DisplayPort - male
2 years warranty
P/N: SV231DPUA, VS421DP, SV431DPUA, SV231DPU
Cable Type
Video adapter
Interface Supported
DisplayPort / HDMI
Length
24 cm
Connector
19 pin HDMI Type A - female
20 pin DisplayPort - male
Service & Support Details
StarTech.com 4 Port DisplayPort Video Switch with Audio & IR Remote Control
StarTech.com DisplayPort to HDMI Video Adapter Converter Bundle deal on StarTech.com DisplayPort to HDMI Video Adapter Converter
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£27.65
67B2 StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £17.66
Price Range Inc VAT: 0 - 50
