BT.com
Wishlist
StarTech.com DisplayPort to HDMI Video Adapter Converter
StarTech.com DisplayPort to HDMI...
£19.10
25 in stock
£19.10
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Connect your HDMI monitor or HDTV to a DisplayPort equipped computer. The StarTech.com DisplayPort to HDMI adapter lets you connect an HDMI-enabled video display to a DisplayPort video source (e.g.DisplayPort video cards, etc.), eliminating the expense of having to upgrade your display for DisplayPort compatibility.
This adapter supports display resolutions of up to 1920x1200 allowing you to take full advantage of HDMI video capability.
DP2HDMI is a passive adapter cable that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
This adapter allows for audio pass-through if supported by the video source. Please review the video source manual to confirm support.
StarTech.com DisplayPort to HDMI Video Converter - video adapter - DisplayPort / HDMI - 24 cm
Cable
Video adapter - DisplayPort / HDMI
Length
24 cm
Connector
DisplayPort - female
Connector (Second End)
HDMI - male
2 years warranty
P/N: SV231DPUA, VS421DP, SV431DPUA, SV231DPU
Cable Type
Video adapter
Interface Supported
DisplayPort / HDMI
Length
24 cm
Connector
20 pin DisplayPort - female
19 pin HDMI Type A - male
StarTech.com 4 Port DisplayPort Video Switch with Audio & IR Remote Control
Accessories
£19.10
£7.21
£48.90
£7.11
Scroll to top
