Click to visit BT.com
BT.com
Wishlist
StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F
Quicklinx: 67CKWS00
Mfr#: DP2HDMIADAP
Express delivery Order within the next 7 hours for delivery tomorrow
37 in stock
£12.26
The DP2HDMIADAP DisplayPort to HDMI Adapter provides a DisplayPort male and HDMI female connector, allowing you to keep your existing (HDMI) display while using a DisplayPort video card/source.
Supporting display resolutions of up to 1920 x 1200(computer)/1080p(HDTV), this cost-effective solution maintains the incredible graphical performance offered by DisplayPort, while eliminating the cost of having to upgrade your HDMI capable display to a display with built-in DisplayPort support.
DP2HDMIADAP is a passive adapter cable that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
Backed by a StarTech.com 1 year warranty and free lifetime technical support.
StarTech Advantage
  • Simple, small form factor converter makes a DisplayPort video card backward compatible with your HDMI display
  • Easy to use, no software or drivers required
  • Supports PC resolutions up to 1920x1200 and HDTV resolutions up to 1080p
  • Easy to use adapter, no software required
Applications
  • The DisplayPort to HDMI adapter allows for an easy and hassle free connection to any HDMI display
StarTech.com DisplayPort to HDMI Video Adapter Converter - video adapter - DisplayPort / HDMI
Cable
Video adapter - DisplayPort / HDMI
Connector
DisplayPort - male
Connector (Second End)
HDMI Type A - female
2 years warranty
Cable Type
Video adapter
Interface Supported
DisplayPort / HDMI
Connector
20 pin DisplayPort - male
19 pin HDMI Type A - female
StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F Bundle deal on StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £5.48 | in stock
£16.35
saving £1.39
67CK StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F In Stock £12.26
Price Range Inc VAT: 0 - 50
