BT.com
Wishlist
StarTech.com DC Power Adapter - 5V, 3A
StarTech.com DC Power Adapter - 5V,...
£12.46
8 in stock
£12.46
Add to wishlist
Delivery
Standard 3-5 working days
Replace your lost or failed power adapter. This replacement power adapter can provide a power source for any electronic device with an M-type barrel requiring up to 5 volts and 3 amps of power.
The adapter is a perfect replacement for the lost or damaged power adapter you've used to power your existing electronics.
When downtime isn't an option, keeping spare power adapters on hand ensures that you won't be left waiting for a replacement to arrive or have to replace your devices just for the sake of a compatible power source.
For frequent travelers, this power adapter saves you from buying multiple adapters. To ensure it will work in your region and the region you're traveling to, the power adapter features 100-240V automatic switching and regional clips for North America, Europe, United Kingdom and Australia.
StarTech.com Replacement 5V DC Power Adapter - 5 Volts, 3 Amps - power adapter
Power adapter - external
160 g
Australia, North America, United Kingdom, Europe
Input Voltage
AC 100-240 V
Output Voltage
DC 5 V
4 power tips
4.6 cm x 8.9 cm x 3.6 cm
2 years warranty
Input Voltage
AC 100-240 V
Output Voltage
DC 5 V
Max Electric Current
3 A
4 power tips
Power cable - integrated
UL, FCC, WEEE
10 - 80%
4.6 cm
8.9 cm
3.6 cm
160 g
Accessories
£55.76
£135.66
£65.36
£118.38
£162.86
StarTech.com VDSL2 Ethernet Extender Kit
Quicklinx: B9GH | In Stock
£222.19
Scroll to top
