BT.com
Wishlist
StarTech.com Bluetooth Audio Receiver with NFC - Wireless Audio
StarTech.com Bluetooth Audio...
£46.54
£46.54
Add to wishlist
Delivery
Standard Due date unavailable
Stream audio from Bluetooth-equipped mobile devices to your A/V equipment, with automatic NFC pairing. The BT2A Bluetooth audio receiver turns your home stereo, or any audio output device into a Bluetooth-compatible media gateway you can use for wirelessly streaming music directly from a Bluetooth-enabled device, such as your Smartphone, Tablet, or iPod Touch.
The Bluetooth receiver delivers hassle-free pairing using NFC (Near field communication) - gently tap your NFC-enabled Bluetooth device on the BT2A and your device will be ready to transmit audio wirelessly through your audio equipment, with no additional configuration required.
To ensure the best sound quality, the BT2A features a Wolfson Digital-to-Analog converter (DAC). Plus, for simple compatibility with your existing devices, the receiver includes analog cabling for connections that require 2-channel RCA audio, or 3.5mm audio.
StarTech.com Wireless Bluetooth Audio Receiver with NFC - Bluetooth wireless audio receiver
Wireless Interface
Bluetooth, NFC
Package Content
AC power adaptor, audio cable, 3.5 mm to RCAx2 adapter, Bluetooth wireless audio receiver
Product Material
Plastic
8.4 cm x 2.6 cm x 7.7 cm
54 g
2 years warranty
Wireless Interface
Bluetooth 2.0, NFC
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP)
Package Content
Product Material
Plastic
8.4 cm
2.6 cm
7.7 cm
54 g
Audio line-out - mini-phone stereo 3.5 mm , Digital audio output (optical) - TOS Link
aptX technology, LED indicator
2 years warranty
Service & Support Details
2 years
Scroll to top
