BT.com
Wishlist
StarTech.com Black 5.25in SATA Hard Drive Mobile Rack Drawer
Delivery
Standard Due date unavailable
Add safe and reliable swappable storage from a single 5.25in front bay. This high quality Removable SATA Hard Drive Drawer/Mobile Rack delivers a convenient SATA hot-swap solution, allowing you to quickly swap Serial ATA hard drives in and out of a computer without having to open the computer case.
Simply install the (included) drive bay into a 5.25in drive bay on the host computer, then mount a 3.5in SATA HDD in the (removable) caddy. Connecting the SATA hard drive to the computer is as easy as inserting the caddy into the drive bay, which can be locked to prevent unauthorized removal of the installed SATA drive.
To maximize performance and utilize the full speed potential of your SATA III hard drives, this HDD Backplane supports SATA III for transfer speeds up to 6 Gbps when paired with compatible controller.
A suitable solution for large volume drives, the HDD drawer supports SATA, SATA II, and SATA III-6Gbps hard drives allowing you to swap in large amounts of data in a matter of seconds. The mobile rack/backplane is fully compatible with RAID installations to ensure maximum performance and versatility for enhanced storage applications.
The drive caddy features a rear panel ball bearing fan that helps keep the enclosed drive cool, in turn helping to optimize operation while preserving drive lifespan. To prevent damage to the hard drive(s) while being transferred in and out of the computer, the drive caddy features shock absorbers and rubber cushioning that help limit vibration/shock to the drive. This mobile rack is also compatible with DRW113-series SATA hard drive caddies.
A dependable, long-lasting storage solution, the drive drawer features highly durable construction, with a 3K insertion rating.
StarTech.com Value Series Black 5.25in SATA Hard Drive Mobile Rack Drawer - storage bay adapter
Storage bay adapter
Expansion Bays
1 x internal - 3.5"
Compatible Bay
1 5.25" x 1/2H
Supported Interface
SATA 1.5Gb/s
Drive Connector
7 pin Serial ATA
Bay Connector
7 pin Serial ATA
Ball bearing cooling fan, data indicator, power indicator, shock protection, key lock, cooling fan
Product Material
Plastic
14.8 cm x 22 cm x 4.1 cm
0.5 kg
2 years warranty
Storage bay adapter
Product Material
Plastic
Supported Interface
SATA 1.5Gb/s
Bays
1 x internal - 3.5"
1 x SATA 1.5Gb/s - 7 pin Serial ATA
1 storage - Serial ATA-150 - 7 pin Serial ATA
Compatible Bay
1 x external 5.25" x 1/2H
14.8 cm
22 cm
4.1 cm
0.5 kg
Accessories
StarTech.com 12in Latching SATA Cable
Quicklinx: 4LSN | In Stock
£4.06
StarTech.com 18in Latching SATA Cable
Quicklinx: 4LTJ | In Stock
£4.56
StarTech.com 24in Latching SATA Cable
Quicklinx: 4LTL | In Stock
£5.01
£5.22
£6.14
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Does the job perfect
Reviewed by Zeth on 15/08/2010
Don't wanna keep opening up your case to upgrade hard drives? These work a treat for me.
I now only keep two drives for data in my pc and another two for back ups in the caddy draws you buy for this. Insert them when I want to back up.
Makes the case less cluttered and saves energy and life span of the back up drives. Ya and cheap as chips!
5* Great item
Reviewed by Anonymous on 21/10/2007
'Cheap as chips'. BT usual super fast delivery. Easy to fit and works straight out of the box.
1* Pay more get a better one
Reviewed by Andy on 17/02/2011
Very flimsey, the interface housing snapped off during installation. Have requested a refund but will return it anyway.
Scroll to top
