BT.com
Wishlist
StarTech.com 92x25mm Dual Ball Bearing Computer Case Fan with LP4 Connector
StarTech.com 92x25mm Dual Ball...
£6.21
15 in stock
£6.21
Add to wishlist
Delivery
Standard 3-5 working days
This 9.2cm x 9.2cm x 2.5cm (3 5/8" x 3 5/8" x 1") dual ball bearing PC case fan is an add-in cooling fan designed to fit most computers. The PC case fan can be used to circulate cool air into the case or exhaust warm air out, preventing problems due to overheating components.
A quiet running brushless ball bearing DC motor coupled with a high efficiency blade design is capable of moving 39.35 CFM (cubic feet per minute) of air.
Power is supplied to the fan using a standard LP4 (hard drive power connector) pass through plug.
StarTech.com 92x25mm Dual Ball Bearing Computer Case Fan w/ LP4 Connector - system fan kit
System fan kit
Fan Diameter
92 mm
Noise Level
32 dB
9.2 cm x 2.5 cm x 9.2 cm
1 year warranty
System fan kit
9.2 cm
2.5 cm
9.2 cm
Heatsink & Fan
Fan Diameter
92 mm
Noise Level
32 dB
Limited warranty - 1 year - carry-in
Accessories
£1.26
Scroll to top
