Click to visit BT.com
BT.com
Wishlist
StarTech.com 92x25mm Computer Case Fan with PWM – Pulse Width Modulation Connector
Quicklinx: 7TX8WS00
Mfr#: FAN9225PWM
Add a variable speed, PWM-controlled cooling fan to a computer case. The FAN9225PWM 92mm PWM case fan adds an efficient air cooling solution to computer cases or other enclosures to keep components running optimally.
With Pulse Width Modulation (PWM) technology, the fan speed can be dynamically controlled by the motherboard, so the fan runs at a speed that suits the operating conditions - lowering power consumption and fan noise when the system is idle, and delivering maximum cooling under full load conditions.
StarTech.com 92x25mm Computer Case Fan with PWM - case fan
Case fan
Package Content
Y-Split cable
Fan Diameter
92 mm
Fan Height
25 mm
Fan Bearing
Ever Lubricate bearing
Rotation Speed
700-2200 rpm
Air Flow
12.8-39.4 cfm
Noise Level
10 - 25 dBA
Power Connector
4-pin fan connector, 4 pin Molex connector
9.2 cm x 9.2 cm x 2.5 cm
96 g
2 years warranty
Case fan
Package Content
Y-Split cable
9.2 cm
9.2 cm
2.5 cm
96 g
Heatsink & Fan
Fan Diameter
92 mm
Fan Height
25 mm
Fan Bearing
Rotation Speed
700-2200 rpm
Air Flow
12.8-39.4 cfm
Noise Level
10 - 25 dBA
Power Connector
RoHS
2 years warranty
Service & Support Details
-10 °C
70 °C
