BT.com
Wishlist
StarTech.com 8U 22in Depth Hinged Open Frame Wall Mount Server Rack
StarTech.com 8U 22in Depth Hinged...
£176.10
£176.10
Add to wishlist
Delivery
Standard Due date unavailable
Wall-mount your server or networking equipment with a hinged rack design for easy access and maintenance. The RK819WALLOH 8U 22in Depth Hinged Open Frame Wall Mount Server Rack lets you wall mount your (19-inch wide) servers, A/V or network equipment and features a hinged rack design that allows the entire frame to swing open for easy installation and maintenance of your equipment.
The 8U wallmount rack offers a 4 post design for additional support of your equipment, storing a maximum weight capacity of 63 kg (140 lbs). Constructed of high-quality SPCC cold-rolled steel for strength and durability, the open frame wallmount server rack allows for maximum airflow, and ships complete with all of the rack screws and cage nuts required to mount your equipment, saving the expense of purchasing them separately.
StarTech.com 8U 22in Depth Hinged Open Frame Wall Mount Server Rack - rack - 8U
Rack
Placing / Mounting
Wall mountable
Rack Size
22"
Height (Rack Units)
8U
Product Material
Cold-rolled steel
60.4 cm x 55.5 cm x 48.8 cm
15.1 kg
Hinged
Rack
Placing / Mounting
Wall mountable
Product Material
Cold-rolled steel
Rack Size
22"
Height (Rack Units)
8U
60.4 cm
55.5 cm
48.8 cm
15.1 kg
Weight Limit
63.4 kg
Mounting Kit
Included
Hinged
EIA-310-D, UL, RoHS
Limited warranty - lifetime
Scroll to top
