BT.com
Wishlist
StarTech.com 8U 19in Wall Mount Side Mount Open Frame Rack Cabinet
StarTech.com 8U 19in Wall Mount...
£301.22
£301.22
Add to wishlist
Delivery
Standard 1-3 working days
Mount your server and networking equipment to the wall, with side mounting for hassle-free access to rear cabling. The RK819SIDEM Side-mounted Wallmount Open Frame Rack/Cabinet is an 8U server rack that lets you mount your (19-inch wide) servers, A/V or network equipment facing perpendicular to the wall, for easy access to mounted devices and equipment. The cabinet/rack features open access to both the front and back of your devices, making it easy to adjust cabling, view LEDs and access configuration buttons as needed. Plus, the nature of the sidemount configuration allows for deeper mounting depths than typical wallmount racks, without causing an obstruction. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
Constructed of high-quality SPCC cold-rolled steel, for strength and durability, the open frame equipment rack allows for maximum airflow while still supporting a maximum weight capacity of 159 kg (350 lbs). The wall mount rack also ships complete with all of the M5 screws and cage nuts required to mount your equipment, saving the expense of purchasing them separately.
StarTech.com 8U 19in Wall Mount Side Mount Open Frame Rack Cabinet - rack - 8U
Rack
Placing / Mounting
Wall mountable
Rack Size
19"
Height (Rack Units)
8U
Product Material
Steel
53.7 cm x 56 cm x 47.8 cm
17.7 kg
Rack
Placing / Mounting
Wall mountable
Product Material
Steel
Rack Size
19"
Height (Rack Units)
8U
53.7 cm
56 cm
47.8 cm
17.7 kg
Weight Limit
159 kg
Mounting Kit
Included
EIA-310-D, UL, RoHS
Limited warranty - lifetime
Scroll to top
