BT.com
Wishlist
StarTech.com 8in LFH 59 Male to Dual Female DVI I DMS 59 Cable
StarTech.com 8in LFH 59 Male to...
£14.97
More than 50 in stock
£14.97
Add to wishlist
Delivery
Standard 3-5 working days
Connect two DVI monitors to your DMS / LFH equipped graphics card.. This DMS 59 to dual DVI Y cable allows you to break out one LFH 59 or LFH 60 (DMS 59 and DMS 60) connection on Matrox Qid, nVidia Quadro, and PNY Quadro graphics cards into two DVI-I Dual Link female connectors - letting you connect two DVI capable monitors for a cost-effective dual monitor solution.
StarTech.com 8in LFH 59 Male to Dual Female DVI I DMS 59 Cable - DVI cable - 20 cm
DVI cable - dual link
Length
20 cm
Connector
2 x DVI-I - female
Connector (Second End)
DMS-59 - male
RoHS
DVI cable
TMDS Links
Dual link
Length
20 cm
Connector
2 x 24+5 pin combined DVI - female
DMS-59 - male
RoHS
Scroll to top
