BT.com
Wishlist
StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included)
StarTech.com 8 Port Rackmount USB...
£295.29
Hurry, only 2 left in stock!
£295.29
Add to wishlist
Delivery
Standard 1-3 working days
Control up to 8 VGA and USB computers from a single keyboard, mouse and monitor. The SV831DUSBAU 8 Port Rack Mount USB VGA KVM Switch (with Audio Cables Included) allows you to control up to 8 USB computers using a single keyboard, mouse and monitor, and features Audio and Microphone ports to switch between audio signals as well as PC ports.
Based on a 1U rack mountable slim form factor design, this 8 Port USB KVM uses rear cable connections to maximize space efficiency. Multiple KVM units can also be connected (cascaded) together for control of up to 64 computers, ensuring a scalable KVM solution that can be expanded as necessary.
To ensure seamless operation, the switch features automatic and manual scan modes, supports both hot-key and front panel push-button switching, and features a convenient OSD (on-screen display) for added configuration options.
StarTech.com 8 Port RackMount USB VGA KVM Switch with Audio - KVM / audio switch - 8 ports - desktop
KVM / audio switch - 8 ports - USB - cascadable
Enclosure Type
Desktop 1U
Subtype
KVM
Ports
8 x KVM / audio
KVM Users Qty
1 local user
On-Screen Display
54 cm x 18 cm x 4.5 cm
3 years warranty
Bundled Services
3 years warranty
P/N: 2636CABINET, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1236BKF, RK12OD, RK2236BKF, RK2536BKF, RK4236BK, RK4242BK, RK960CP, RKQMCAB12, RKWOODCAB12
KVM / audio switch - 8 ports - cascadable
Enclosure Type
Desktop 1U
Subtype
KVM
Ports
8 x KVM / audio
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1440
On-Screen Display
8 x KVM - HD-15 , 8 x microphone - mini-jack , 8 x audio - mini-jack , 1 x VGA - HD-15 , 1 x keyboard (USB) - Type A , 1 x mouse (USB) - Type A , 1 x microphone - mini-jack , 1 x audio - mini-jack
Internal power supply
16 x audio cable - 1.8 m
Rack Mounting Kit
Included
FCC, RoHS
54 cm
18 cm
4.5 cm
Limited warranty - 3 years
5 °C
Accessories
£4.11
£4.14
£14.59
£9.22
Scroll to top
