BT.com
Wishlist
StarTech.com 8 Port Low Profile RS232 PCI Serial Card with 16950 UART
Delivery
Standard Due date unavailable
The PCI8S950LP PCI Serial Card (16950 UART) lets you turn a single low profile PCI slot into eight RS232 (DB9) serial connections. The unique design of the serial card and included break out cable feature a VHDCI (Very High Density Cable Interconnect) connector, enabling the addition of 8 serial interfaces while only using a single expansion slot. The 8-port serial adapter card is compatible with a broad range of operating systems, including Windows 2000/XP/2003/Vista/7, as well as Linux Kernel 2.4.x and up.
StarTech.com 8 Port Low Profile RS232 PCI Serial Card with 16950 UART - serial adapter
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI-X
Ports
RS-232 x 8
5 cm x 12.6 cm x 2 cm
60 g
Cabling Type
Serial RS-232
Serial adapter
PCI-X
Ports
RS-232 x 8
Wired
Cabling Type
Serial RS-232
8 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x PCI-X
WHQL, FCC, RoHS
Software Included
Drivers & Utilities
5 cm
12.6 cm
2 cm
60 g
Limited warranty - lifetime
-20 °C
85 °C
5 - 85%
Accessories
£4.58
£5.13
£4.66
£4.39
£4.22
£19.65
StarTech.com Serial Null Modem Adapter
Quicklinx: 76P7 | In Stock
£5.17
£5.17
Scroll to top
