BT.com
Wishlist
StarTech.com 8 Port High Speed HDMI Video Splitter w/ Audio - Rack Mountable
StarTech.com 8 Port High Speed HDMI...
£337.89
Hurry, only 2 left in stock!
£337.89
Add to wishlist
Delivery
Standard 1-3 working days
Split an HDMI audio and video signal to eight displays simultaneously.
The ST128HDMI2 8-Port High Speed HDMI Splitter (rack mountable) lets you share a single HDMI audio-video source with up to 8 HDMI or DVI-D displays without sacrificing image or sound quality.
Supporting True HD 1080p video resolutions, the HDMI splitter acts as a distribution amplifier that enables you to situate your HDMI-capable displays up to 50ft (15m) away from the splitter, and features 3.5mm audio connections, giving you the option of sending your accompanying audio signal through the HDMI cable, or through a separate channel.
A perfect addition to virtually any application requiring the high quality video, the ST128HDMI2 HDMI splitter is easy to install as a standalone or rack-mounted device using the included brackets and provides flawless, distortion-free digital video.
StarTech.com 8 Port High Speed HDMI Video Splitter w/ Audio - Rack Mountable - video/audio splitter - 8 ports - rack-mountable
Video/audio splitter - 8 ports - cascadable
Enclosure Type
Rack-mountable
Subtype
HDMI
Ports
8 x HDMI
AC 120/230 V
18.5 cm 4.4 cm
3.5 kg
3 years warranty
Bundled Services
3 years warranty
Enclosure Type
Rack-mountable
Subtype
HDMI
Ports
8 x HDMI
Max Units In A Stack
3
Max Resolution
1080p
HDTV support
Status Indicators
Port status, power
8 x HDMI , 1 x HDMI , 1 x audio input - mini-jack , 8 x audio output - mini-jack
External power adapter
AC 120/230 V
10.2 Watt
Rack Mounting Kit
Included
FCC, RoHS
18.5 cm
4.4 cm
3.5 kg
3 years warranty
Limited warranty - 3 years
0 - 80%
Min Storage Temperature
-10 °C
Max Storage Temperature
60 °C
Accessories
£9.12
Scroll to top
