BT.com
Wishlist
StarTech.com 8 Port 10/100 PSE Industrial Power over Ethernet Switch - All 8 Ports PoE
Delivery
Standard Due date unavailable
Connect Power and Data to 8 PoE-enabled Devices, with 15.4W per Port Output. The IES8100POEGB 8-port 10/100 Mbps Power over Ethernet (PoE) Switch enables you to supply both power and data to up to 8 PoE-capable devices.
The switch complies with 802.3af standards and supplies up to 15.4 W per port - plenty of power for your PoE devices. A flexible solution giving you the freedom to place your equipment in locations where power outlets are not available, this compact PoE Switch features 8 auto-detecting full/half-duplex ports with automatic crossover detection (MDI/MDI-X). A sturdy metal enclosure provides durability in harsh industrial environments.
StarTech.com 8 Port 10/100 PSE Industrial Power over Ethernet Switch - switch - 8 ports - rack-mountable
Switch - 8 ports
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
8 x 10/100 (PoE)
Power Over Ethernet (PoE)
PoE
Power over Ethernet (PoE), auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode
IEEE 802.3, IEEE 802.3u, IEEE 802.3af, IEEE 802.3x
26.6 cm x 16 cm x 4.4 m
1.4 kg
United Kingdom
2 years warranty
Switch - 8 ports
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Fast Ethernet
Ports
8 x 10/100 (PoE)
PoE
RAM
512 KB
Status Indicators
Power, PoE, link/activity
8 x 100Base-TX RJ-45 PoE
External power adapter
UL, FCC, RoHS
United Kingdom
26.6 cm
16 cm
4.4 m
1.4 kg
45 °C
10 - 95%
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Accessories
£4.60
£122.37
Scroll to top
