BT.com
Wishlist
StarTech.com 75 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F
Delivery
Standard 3-5 working days
This 75ft High Resolution VGA Extension Cable is designed to provide the highest video quality possible through VGA.
Ideally suited for high resolution VGA applications, this high quality male to female coaxial VGA extension cable helps to eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com Coax High Resolution VGA Monitor Cable - VGA extension cable - 22.9 m
VGA extension cable
Coaxial
Molded, ferrite bead
Length
22.9 m
Connector
HD-15 - male
Connector (Second End)
HD-15 - female
FCC
VGA extension cable
Coaxial
Length
22.9 m
Connector
15 pin HD D-Sub (HD-15) - female
FCC
Scroll to top
