BT.com
Wishlist
StarTech.com 70 ft Coax High Resolution Monitor VGA Cable - HD15 M/M
Delivery
Standard Due date unavailable
This 70-foot High Resolution VGA Monitor Cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications, this high quality male-to-male coaxial VGA cable eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial cables, while providing superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 70 ft Coax High Resolution Monitor VGA Cable - HD15 M/M - VGA cable - 21.3 m
VGA cable
Triple shielded twisted pair coaxial
Ferrite bead
Length
21.3 m
Connector
HD-15 - male
Connector (Second End)
HD-15 - male
NEC-CMG
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Ferrite bead
Length
21.3 m
Connector
NEC-CMG
Accessories
£7.30
Scroll to top
