BT.com
Wishlist
StarTech.com 7 Port Black USB 2.0 Hub
StarTech.com 7 Port Black USB 2.0...
£21.56
£21.56
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
This 7 Port USB 2.0 Hub connects to one USB 2.0 port on a Mac or PC computer, adding seven USB 2.0 ports - allowing you to maximize the number of high speed USB peripherals connected to your computer. The hub supports cascaded installation with other USB 2.0 hubs, supporting up to 127 USB 2.0 device connections - a scalable solution for connecting multiple USB devices to a single host computer.
The 7 port hub includes a power adapter, but can be powered through USB bus connection to the host computer - allowing you to install the hub as needed without worrying about the availability of a power outlet.
The USB 2.0 hub offers an attractive black casing that suits any operating environment and includes a 3ft USB 2.0 A/B male-male cable, for the connection between the hub and the host computer.
StarTech.com 7 Port Compact Black USB 2.0 Hub - hub - 7 ports - desktop
Hub - 7 ports
Enclosure Type
Desktop
Subtype
USB
Ports
7 x USB 2.0
4.8 cm x 8 cm x 2.5 cm
272 g
Apple MacOS 8.6 or later, Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows Vista, Microsoft Windows 2003
United Kingdom
1 year warranty
Bundled Services
1 year warranty
Hub - 7 ports
Enclosure Type
Desktop
Subtype
USB
Ports
7 x USB 2.0
Status Indicators
7 x USB 2.0 - Type A , 1 x USB 2.0 - Type B
External power adapter
1 x USB cable - 91 cm
UL, FCC, RoHS
United Kingdom
Software Included
Drivers & Utilities
4.8 cm
8 cm
2.5 cm
272 g
Limited warranty - 1 year
Accessories
£5.20
£4.58
£3.79
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* No problems with mine.
Reviewed by Anonymous on 12/10/2011
I bought one of these from BT ages ago and have had no problems with it. I have never used it without power, but I did buy this one because I wanted a powered hub anyway. There are no LEDs on it, but I've never found much value in them on USB hubs anyway, and this just saves on a (little bit!) of power. I like the design because three of the ports are on the back (for devices that are rarely unplugged) and four on the front which provide easy access for devices that are plugged/unplugged regularly (cameras, USB sticks, etc.) Considering that some of the USB 2 hubs I'm seeing on here are around the £50 mark, I think I'd be hard pressed to beat this one on value for money.
2* Intermittant
Reviewed by Anonymous on 09/10/2011
Occasionally my computer recognises the device. When it does it works well. External power source (included) seems to be vital. Others might have more luck with it than me.
Scroll to top
