BT.com
Wishlist
StarTech.com 7.1 USB Audio Adapter External Sound Card with SPDIF Digital Audio
StarTech.com 7.1 USB Audio Adapter...
£27.20
13 in stock
£27.20
Add to wishlist
Delivery
Standard 3-5 working days
Turn your laptop or desktop computer into a 7.1-channel home theater-ready sound system. This versatile External USB Sound Card/Audio Adapter offers a high quality solution for upgrading desktop or laptop sound.
Providing a robust USB audio experience, the USB sound card connects to a host computer through a single USB 2.0 connection, to deliver impressive external audio capability that can instantly be swapped between systems, without having to open the computer case for installation.
Supporting analog and digital audio for 2 to 7.1 channel audio applications, the external USB sound card provides a cost-saving upgrade from built-in/on-board sound that turns desktop/laptop sound into a home theater-ready audio solution.
The external USB sound card features easy-to-use volume control and two external microphone inputs - a convenient solution for any audio application requiring high quality sound with multi-input capability with support for 44.1 KHz and 48 KHz sampling rates for both playback and recording.
A more than suitable solution for home theater, gaming or multi-media presentations, the External USB Sound Card is easy to install with plug and play support in Windows XP and Windows Vista operating systems.
The audio adapter's SPDIF optical pass-through port supports two-channel audio, this port does not support 5.1 or 7.1 audio.
StarTech.com 7.1 USB Audio Adapter Sound Card with SPDIF Digital Audio - sound card
Sound card
Enclosure Type
External
Interface Type
USB 2.0
10 cm x 6 cm x 2.5 cm
100 g
Sound Output Mode
7.1 channel surround
Sample Rate
48 kHz (max)
Hardware Controls And Indicators
Volume control, mute button
Microsoft Windows 2000 Server, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits), Windows 8.1 (32/64 bits), Windows 10 (32/64 bits)
2 years warranty
Sound card
External
Interface Type
USB 2.0
10 cm
6 cm
2.5 cm
100 g
Enclosure Colour
Silver
Audio Output
Sound Output Mode
Sample Rate
48 kHz (max)
1 x headphones - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x speakers (side surround) - mini-phone stereo 3.5 mm , 1 x speakers (center/subwoofer) - mini-phone stereo 3.5 mm , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x speakers (back surround) - mini-phone stereo 3.5 mm , 1 x SPDIF output - TOSLINK , 1 x SPDIF input - TOSLINK , 2 x microphone - mini-phone stereo 3.5 mm
Plug and Play, FCC, RoHS
Software
Drivers & Utilities
Limited warranty - 2 years , Technical support - lifetime
55 °C
20 - 80%
StarTech.com 7.1 USB Audio Adapter External Sound Card...
£27.20
Save on this ideal PC Build kit!
Save £8.29
£46.37
Scroll to top
