BT.com
Wishlist
StarTech.com 6in 20 Pin ATX Power Supply to 24 Pin Motherboard Adapter
Delivery
Standard Due date unavailable
Just because your motherboard has a 24-pin ATX connector, it doesn't mean you have to pay for an expensive 24-pin ATX power supply. This adapter cable turns your power supply's 20-pin male ATX connector into the 24-pin male ATX connector needed by high-end motherboards. This reliable power adapter is backed by our lifetime warranty.
  • Eiminates the need to purchase an expensive power supply with 24-pin power connector to replace your existing 20-pin power supply
  • StarTech.com's lifetime warranty
  • StarTech.com's adapter cable converts your existing standard 20-pin ATX power supply to work as a 24-pin ATX power supply
StarTech.com 20 Pin ATX Power Supply to 24 Pin Motherboard Adatper - power connector adaptor - 15.2 cm
Power connector adaptor
Length
15.2 cm
Connector
Power 20 pin ATX - male
Connector (Second End)
Power 24 pin ATX - female
P/N: ATXPOW330HS, ATXPOWER300B, ATXPOW400DF, ATXPOW350PRO, ATXPOW350DF, ATXPOW250PRO, ATXPOWER250, ATXPOWER300
Length
15.2 cm
Connector
FCC, RoHS
P/N: ATXPOW250PRO, ATXPOW330HS, ATXPOW350DF, ATXPOW350PRO, ATXPOW400DF, ATXPOWER250, ATXPOWER300, ATXPOWER300B
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
1* description wrong
Reviewed by andy on 22/11/2006
The description is wrong. This product converts a 20 pin PSU to a 24pin motherboard.
NOT the other way round.
Scroll to top
