BT.com
Wishlist
StarTech.com 6 ft USB 2.0 Extension Cable A to A - M/F
StarTech.com 6 ft USB 2.0 Extension...
£4.23
More than 50 in stock
£4.23
Add to wishlist
Delivery
Standard 3-5 working days
This high quality 6ft USB A-A extension cable features one USB A male connector and one USB A female connector, extending the connection between USB 2.0 devices by up to 6 feet - an ideal solution for better placement of peripheral devices, or adding flexibility to existing USB ports. The USB extension cable is fully rated for use with USB 1.1 and USB 2.0 devices.
StarTech.com 6 ft USB 2.0 Extension Cable A to A - M/F - USB extension cable - 1.8 m
USB extension cable
Molded
Length
1.8 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type A - female
P/N: RKCONS2001GB, RACKCONS2001, DP2DVID, USB2IR2, 35FCREAD20, 35FCREAD20BK, CB100LANUSB2, USB555WG, 35FCREAD, 35FCREADBK, FCREADMINI, 35FCREADREM
USB extension cable
Molded
Length
1.8 m
Connector
StarTech.com 10/100 Ethernet + USB 2.0 Slot Saver CardBus Card, 20-in-1 3.5" Bay Flash Memory Card Reader, 35FCREAD, 35FCREADBK, 35FCREADREM, 7-in-1 USB 2.0 Multi Media Memory Card Reader, DisplayPort to DVI Dual Link Active Converter – USB Powered, High Res RackMount LCD Console for 19" Rack, USB to Infrared/IrDA SIR Adapter, USB Wireless Network Adapter
Accessories
£4.23
Scroll to top
