Click to visit BT.com
BT.com
Wishlist
StarTech.com 6 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k
Quicklinx: 679WWS00
Mfr#: DISPLPORT6L
Type: Video
Length: 1.8m
Express delivery Order within the next hour for delivery tomorrow
21 in stock
£10.22
Create high-resolution 4k x 2k connections with HBR2 support between your DisplayPort-equipped devices. The DISPLPORT6L 6ft DisplayPort 1.2 Cable with latches provides a secure, connection between your DisplayPort-equipped devices and is capable of providing higher performance than either HDMI or dual link DVI.
The DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
StarTech.com DisplayPort 1.2 cable with latches - certified, 6 ft - DisplayPort cable - 1.8 m
DisplayPort cable
Shielded
Cable Features
Latched , nickel plated connectors
Length
1.8 m
Connectors
1 x 20 pin DisplayPort - male
Connectors (Other Side)
P/N: SV231DPUA, VS421DP, SV231DPDDUA, SV431DPUA, SV231DPU
DisplayPort cable
Shielded
Shielding Material
American Wire Gauge (AWG)
30
Cable Features
Length
1.8 m
Colour Category
Connectors
StarTech.com 4 Port DisplayPort Video Switch with Audio & IR Remote Control
StarTech.com 6 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k Bundle deal on StarTech.com 6 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £5.48 | in stock
£14.31
saving £1.39
Type: Video
Length: 1.8m
Price Range Inc VAT: 0 - 50
