BT.com
Wishlist
StarTech.com 6 ft 90 Degree Upward Angled Dual Link DVI-D Monitor Cable - M/M
StarTech.com 6 ft 90 Degree Upward...
£9.70
2 in stock
£9.70
Add to wishlist
Delivery
Standard 3-5 working days
Provides a high speed, crystal clear connection between your DVI devices, even in tight spaces. The DVIDDMMTA6 6ft Dual Link DVI-D cable features a standard DVI-D dual link connector as well as a DVI-D dual link connector that is situated on an upward angle relative to the shaft of the cable, requiring only 40mm of space at the connection point.
The perfect solution for making digital video connections in tight spaces, the design of the upward angle cable connector helps prevent damage to the cable and ensures long-lasting performance by eliminating the need to bend or strain the cable to account for a lack of space.
The 6ft DVI-D digital monitor cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec, and is fully compliant with DVI DDWG standards.
StarTech.com 90 Degree Upward Angled Dual Link DVI-D Monitor Cable - M/M - DVI cable - 1.8 m
DVI cable - dual link
90 degree connector
Length
1.8 m
Connector
DVI-D - male
Connector (Second End)
DVI-D - male
RoHS
P/N: SV231DVIUAHR
DVI cable
American Wire Gauge (AWG)
28
TMDS Links
Dual link
Plated Connector
Nickel
90 degree connector
Length
1.8 m
Connector
24 pin digital DVI - male
RoHS
P/N: SV231DVIUAHR
Accessories
£11.96
£9.70
Scroll to top
