Click to visit BT.com
BT.com
Wishlist
StarTech.com 6 ft 90 Degree Upward Angled Dual Link DVI-D Monitor Cable - M/M
Quicklinx: 6PDTWS00
Mfr#: DVIDDMMTA6
Type: DVI
Length: 1.8m
Stock Status: Clearance
Express delivery Order within the next 23 hours for delivery on Friday
Hurry, only 3 left in stock!
£6.18
Provides a high speed, crystal clear connection between your DVI devices, even in tight spaces. The DVIDDMMTA6 6ft Dual Link DVI-D cable features a standard DVI-D dual link connector as well as a DVI-D dual link connector that is situated on an upward angle relative to the shaft of the cable, requiring only 40mm of space at the connection point.
The perfect solution for making digital video connections in tight spaces, the design of the upward angle cable connector helps prevent damage to the cable and ensures long-lasting performance by eliminating the need to bend or strain the cable to account for a lack of space.
The 6ft DVI-D digital monitor cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec, and is fully compliant with DVI DDWG standards.
StarTech.com 90 Degree Upward Angled Dual Link DVI-D Monitor Cable - M/M - DVI cable - 1.8 m
DVI cable - dual link
Cable Features
90 degree connector , nickel plated connectors
Length
1.8 m
Connectors
1 x 24 pin digital DVI - male
Connectors (Other Side)
RoHS
P/N: SV231DVIUAHR
DVI cable
American Wire Gauge (AWG)
28
TMDS Links
Dual link
Cable Features
Length
1.8 m
Colour Category
Connectors
RoHS
P/N: SV231DVIUAHR
StarTech.com 6 ft 90 Degree Upward Angled Dual Link DVI-D Monitor Cable - M/M Bundle deal on StarTech.com 6 ft 90 Degree Upward Angled Dual Link DVI-D Monitor Cable - M/M
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £14.98 | while stocks last
£16.17
saving £4.99
6PDT StarTech.com 15 ft DVI-D Dual Link Monitor Extension Cable - M/F In Stock £11.11
6PDT StarTech.com 6 ft 90 Degree Upward Angled Dual Link DVI-D Monitor Cable - M/M In Stock £6.18
Type: DVI
Length: 1.8m
Price Range Inc VAT: 0 - 50
