BT.com
Wishlist
StarTech.com 6 ft 90° Upward Angled High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable
Delivery
Standard Due date unavailable
Create Ultra HD connections between your HDMI -enabled devices, even in tight spaces. The HDMMU6 90° Upward Angled HDMI Monitor Cable is designed to provide crystal clear image resolution and is specifically constructed to fit into tight installation spaces.
This high quality cable features a 90° upward-angled plug, which requires only 34mm (1.27") of space to make the video connection.
The design of the upward angle cable connector helps prevent damage to the cable and ensures long-lasting performance by eliminating the need to bend or strain the cable to account for a lack of space.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com 90° Upward Angled High Speed HDMI Cable - HDMI - M/M - HDMI cable - 1.8 m
Cable
HDMI cable
Shielded
American Wire Gauge (AWG)
28
Length
1.8 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
90° connector
Cable Type
HDMI cable - 90° connector
Shielded
28
Shielding Material
Length
1.8 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
Scroll to top
